Couple codes...where to start
98 z28,6 speed....car is down on power and CEL is on...codes are
p0131
p0151
p0418
looks like both pre cat o2's and one of the air pump relays.
what should i check first...just replace o2's or could something else be causing the codes?
should i try replacing the air pump relay or maybe a fuse or could it be something else? what side is "a" the 418 code?
thanks in advance for the help
p0131
p0151
p0418
squarehead
Jan 15, 2015 07:02 PM
