heads cam 330 hp
Old Jan 27, 2010 | 03:16 AM
chevylscb's Avatar
heads cam 330 hp
i got a 98 camaro z28 automatic with stage 2 ported polish heads with 228rcam from texas speed 588 lift intake 588 lift exhaust 112 lope seperation stock intake ls6 ported polish oil pump an its tuned it gave me 332hp an 328tq tell me was wrong
Old Jan 27, 2010 | 07:48 AM
AL SS590 M6's Avatar
Moderator
What exhaust? Stock intake isn't helping. Slipping trans could waste a lot of power to the wheels.
Old Jan 27, 2010 | 09:25 AM
4birdman's Avatar
Yeah, that stock intake is really sucking up some power. What exhaust do you have? That might be hurting a bit too depending on what you've got.
That is really low for that H/C setup. My 98 TA made 300rwhp bone stock untuned with just a lid through an automatic, you should be making a lot more than 330hp.
Old Jan 27, 2010 | 03:57 PM
Wicked 97TA's Avatar
How restrictive is the LS1 intake vs. the LS6 intake?
Old Jan 27, 2010 | 05:57 PM
Kraest's Avatar
Retired
On what dyno? Could be possible on a Mustang dyno with retarded timing due to an exhaust leak. Heads ported by whom? The LS1 intake is a big hinderance on a heads/cam setup.
Old Jan 28, 2010 | 12:54 AM
rod442's Avatar
He sent me in a PM from his other post, that they tuned it with an exhaust leak, and thats what it made on the dyno. It now has a chk eng light, and is running poorly.
I suggested that he fix the exh leak, pull the codes and see what they are, and post them here. then if it seems like its got problems, do a comp test and maybe a leakdown to see if the motor's healthy.
After that if he could get some data logs via autotap or whatever (when its running correctly) one of you guys thats a abit more experianced with that could help.
And to post the exhaust setup, and what converter in it. I also asked him if they messed with the shift points when it was tuned. And what type of dyno it was on.
no response back yet.
Old Jan 28, 2010 | 07:36 AM
4birdman's Avatar
I'm betting that something is screwed up in the tune. An exhaust leak won't do jack unless it is bad enough to confuse the knock sensor, which it might be if the timing is getting retarded like Kraest said.
The LS1 intake is very restrictive over the LS6. I've seen cars pick up 15rwhp with an LS6 intake swap.
Old Jan 28, 2010 | 01:19 PM
WhiteHawk's Avatar
Take it to the track and see what you picked up. Sometimes it is hard to copmpare dyno numbers on an auto.
-Geoff
Old Jan 28, 2010 | 11:51 PM
Sk8phreak88's Avatar
It will if it's enough to cause the 02 sensor to read lean.. In turn making the computer shoot more fuel in and running way rich.. (My lt1 is doing the samething right now.)
Old Jan 29, 2010 | 02:35 AM
chevylscb's Avatar
well i got true dual exhaust an stock intake
Old Jan 29, 2010 | 06:36 AM
rod442's Avatar
What headers? size of pipes? x or h pipe, and what mufflers?
Old Jan 29, 2010 | 06:29 PM
SSwolf's Avatar
I have an '01 LS1 with texas speed stage II 5.3 heads and the 224 cam and it puts out over 400 HP. I can tell you what I have and maybe you can compare.
LS6 intake and MAF
LS6 ported oil pump
1 5/8" long tube headers, no cats, and spintech mufflers
The bottom end even has around 100K miles
good luck
mikey4play
Mar 15, 2015 11:45 AM
armedtrigger
Feb 24, 2015 08:30 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Rich_z28
Aug 27, 2002 12:20 AM
