Bad oil pressure reading.....
Old Aug 25, 2010 | 04:02 PM
Sunsetmaro's Avatar
Ok. So i recently got a beater to drive back and forth to work so I could finally put the camaro back in storage. I began last week to take off everything, intake manifold, injectors, intake, valve covers, etc. After everything was spit polished, I put everything back on. Started it up today and had it fully warmed up, checking for leaks, etc. After everything was looking good, I got into the car and noticed the oil pressure guage reading past 80.... Did I hit something during the tear down?
Old Aug 25, 2010 | 06:08 PM
Sunsetmaro's Avatar
Nevermind. Felt behind the intake and pulled out the broken sending unit.......DOH!
Old Dec 23, 2010 | 03:07 PM
MeanZ687's Avatar
Re: Bad oil pressure reading.....
I have a question also.. when I am idling after the engine is warm my oil pressure gauge bounces back and forth a little bit. I was wondering if it's just a loose gauge cable or if something is up with the pressure?
99 Camaro SS 96,435 miles
Old Dec 24, 2010 | 05:57 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by MeanZ687
I have a question also.. when I am idling after the engine is warm my oil pressure gauge bounces back and forth a little bit. I was wondering if it's just a loose gauge cable or if something is up with the pressure? 99 Camaro SS 96,435 miles
A bounching oil pressure gauge often means air in the oil. On an LS1 that would mean that the oil pump to oil pickup O-ring is bad and needs to be fixed.
But first put a manual oil pressure gauge on it to verify that it's not a gauge/sender problem.
Old Dec 28, 2010 | 04:24 PM
MeanZ687's Avatar
It only happens when it's hot out and im just sitting still and not moving. Whens it cold like it is now it's normal
Old Dec 28, 2010 | 04:56 PM
MeanZ687's Avatar
If this is the case of the O ring, is it a serious problem and is it an easy fix?
Old Jan 3, 2011 | 08:23 AM
dragontau313's Avatar
to replace the o ring you have to drop the oil pan and take off the oil pick up tube, there will be an o ring on it, just slide it off and put a new one on. It is just getting tot he oil pan that is a little tricky.
as far as if the air in the oil is bad, if the o ring completely fails, then the you won't get any oil pressure at all.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
