5.3 swap q's
Old Feb 4, 2010 | 10:02 PM
AMERICANMUSCLE89's Avatar
5.3 swap q's
Hey guys im a long time site stalker newb poster.
Im going to b installing a 5.3 truck engine/4L60E tranny in a 1983 Camaro and i have a bunch of questions.
1. What if any stock manifolds will clear
2. How do you rig up your fuel pump? Is there a way to make it work with the stock pickup or is it just better to run an inline? Also does anyone have a part # for the vett fuel filter with built in regulator?
3. Can you keep the cruise control?
4. What did you do about your speedo? The converters are very $$$$
5. Does the factory Cross Mem. have to be moved to bolt the tranny down?
6. Do i need to grab the drive shaft out of the truck or will the 700r4 yolk fit?
7. With the truck intake will it clear a factory hood?
8. What oil pan did you use?
9. Where is a good place (and cheap) to get the puter flashed to remove the VAT
10. Does the computer need to be re prog. to change out the truck intake with a car intake,rails, and inj.?
11. Will my stall in my 700r4 work in the 4l60e? Also i dont remember if it is a lock up or not, will it hurt anything if the tranny tries to lock and it's not ment to lock?
12. How did you do your power steering? I have seen people make brackets to bolt the old style to the 5.3, but what do you do about the pully? Can you by a ribed pully?
Old Apr 1, 2010 | 11:26 AM
jag4902's Avatar
5.3 swap
I am planning the same project but on a 69.
I have been told to use a LS1 or LS6 intake. The truck intake will clear but looks crappy.
go here for a great write-up.
http://www.ls1tech.com/forums/conver...de-1500-a.html
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
fift5
11
Oct 1, 2015 10:31 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
