LS6 knock sensor replacement...
Old Feb 17, 2010 | 06:25 AM
Blue89Bird's Avatar
Anybody have a how to guide to this?
My car started throwing a code for low voltage at the rear sensor so I'm assuming I should just replace them both.
I was looking at diagrams and it appears to be under the intake? Sounds about as stupid at the opti location on the LT1's.
Old Feb 17, 2010 | 09:08 AM
rod442's Avatar
they are under the intake. BUT with a dry intake, and usually reuseable gaskets; its easy to do.
basically dont break the oil pressure sensor that is just behind the intake, and retorq it properly, and its cake.
and I thought the ls6 knock sensor's were MORE sensitive than ls1's. so you might not want to go that route. oops, you have a V, which is a ls6. NM.
Old Feb 17, 2010 | 11:53 AM
henryz28's Avatar
http://ls1howto.com/index.php?article=5
Old Feb 17, 2010 | 12:20 PM
johnny6's Avatar
It's a little pain in the *** but it can be done in a couple of hours. As mentioned above, there's a vaccum line that runs behind the oil pressure sending unit, if you pull the intake out without moving the rubber line you'll snap the sensor off.
Old Feb 17, 2010 | 05:32 PM
Blue89Bird's Avatar
doesn't look horrible I suppose...its freaking cold out though, so I'm gonna wait until it gets a bit warmer. Hopefully shouldn't cause any damage. I'd imagine it's just pulling timing at the expense of hp.
What about the actual replacing of the sensor..is it a simple R&R or anything special needed?
Old Feb 17, 2010 | 07:05 PM
johnny6's Avatar
It's actually two sensors that you'll be replacing, once the intake comes off here's what you'll see:
And to remove the sensors you'll first do this:
Once the connectors are off you'll have to unscrew them with a socket wrench:
Go to this website and it'll show you step by step (F-body) how to remove the intake.
http://www.ls1howto.com/index.php?article=5
Old Feb 18, 2010 | 06:10 PM
bwarren337's Avatar
just dont break the oil pressure sensor cause its about 80 bucks for replacement.... just be careful and you'll be fine that ls1 howto guide is really good.
HectorM52
Jul 30, 2017 11:46 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
