switching exhuast
Old Mar 13, 2010 | 06:25 PM
MeanZ687's Avatar
switching exhuast
I currently have the magnaflow cat-back system on a 99 SS and have had it for about 4 years and i want something that sounds meaner.. I have a shop that makes all their own piping and is gonna make me and off road y-pipe 3".Would the magnaflow muffler sound meaner with that or should i switch up mufflers?
Old Mar 13, 2010 | 06:26 PM
MeanZ687's Avatar
Or what would be the best performing muffler with that?
Old Mar 13, 2010 | 06:45 PM
johnny6's Avatar
The only way to really increase the sound is to install long tube headers which eliminate the cats. I also have a magnaflow and it's prety loud.
Old Mar 13, 2010 | 07:46 PM
MeanZ687's Avatar
well I mean like borla, corsa, and loudmouth sound insane loud but really expensive
Old Mar 13, 2010 | 07:56 PM
johnny6's Avatar
Loudmouth would be your best option, borla and corsa aren't that loud. You could always get a cutout but in my opinion they don't sound very good/
Old Mar 13, 2010 | 11:36 PM
RedHottG2's Avatar
Long tube headers and a TSP true dual x-pipe kit. That's what I have and it's INSANELY loud.
Old Mar 14, 2010 | 08:35 AM
AL SS590 M6's Avatar
Moderator
What are you talking about? He said 3'' OFF-ROAD Y-pipe. Just opening up the Y and removing the cats WILL make it louder, quite a bit louder. And it should sound good thru the magnaflow.
Old Mar 14, 2010 | 09:54 AM
johnny6's Avatar
He never said anything about removing the cats. When my friend installed his Y pipe while keeping his cats, there wasn't much of a sound increase on his Corsa exhaust, he ended up just using a cutout.
Old Mar 15, 2010 | 07:15 AM
Stainless Works's Avatar
Our chambered system sounds pretty wicked
http://www.youtube.com/stainlesswork...22/X887tqXE_j0
Old Mar 15, 2010 | 07:33 AM
Kraest's Avatar
Retired
Al is right -- an OFFROAD Y-pipe is a Y-pipe that lacks cats. It will be a little louder.
Old Mar 16, 2010 | 03:51 PM
MeanZ687's Avatar
What is the difference between the regular slp loudmouth and the newer loudmouth 2?
Old Mar 16, 2010 | 11:10 PM
Kraest's Avatar
Retired
One sounds like **** and the other sounds like loud ****.
Old Mar 17, 2010 | 07:44 AM
Moderator
Come on Mike let's give some actual info.
The Loudmouth is a wide open mandrel bent 3'' catback with just a resonator to cancel some sound. It's not bad if you still have the stock y-pipe and cats. Without cats it's nasty loud.
The Loudmouth II has a bullet muffler instead of a resonator and is much quieter with or without cats but is still nasty loud with long tubes and no cats.
Performance wise it works. I had a Loudmouth that I converted to a Loudmouth II on the race car then converted to true duals with an X-pipe and gained a very tiny bit at the 1/4 mile.
Old Mar 17, 2010 | 09:42 AM
Kraest's Avatar
Retired
Opinions aren't info??
Old Mar 17, 2010 | 01:00 PM
WhiteHawk's Avatar
I think the Mgnaflow is already pretty much a straight flow through, Isn't it? CHambered mufflers always sound better, but you do sacrifice some horses for them. There is probably not much on the table by upgrading from your magnaflow.
I would definitely try it with the offroad Y before changing it. If you end up with a drone, try putting a couple bullet mufflers in the Y, I did that and it deepened up the sound a bit without restricting the flow.
-Geoff
