F14 cam and Dart 225 Heads question
With my current specs below, about what HP will i be around if I put Dart 225 head on with my F14 cam. I am currently putting down 403rwhp with just the cam. I dont want to spend $2000 for heads, plus install, if I wont get much. I dont plan on getting a fast intake soon either.
Also, I found the heads complete for around $1700 and I found a bare heads setup for $1100 on ebay.. Can I just get the bare setup on ebay since I already upgraded to patriot dual valve springs, and pushrods, timing chain and ls6 oil pump? Whats the difference in the two setups?
Thanks guys for any input...
So I should just spend the $500 and get the whole thing with springs and everything? Is there anything I need to replace while doing the heads as a "while I'm here i should replace this" measure? Thanks Marc 85z28 so far..
Yes, replace the lifters with new factory replacement (they are the LS7 lifters) ones. You have a big cam so I assume that you already have hardened pushrods. Make sure and check pushrod length and valvetrain geometry.
And if you can afford the extra $20 or so, get replacement lifter trays - LS2 style.
Personally I'd go with a set of 243 heads ported from AI, around the same money and those heads seem to run (~1,500 set up if you don't have 243 heads). Or save some more and cough up the dough for AFR210 or TFS215.
Assembled heads are usually a bargain if they use decent parts. Dart's are usually ok. For $600 in this case you get valves, springs, spring cups, valve seals, shims, a valve job and the setup. You need to do the math for your situation and verify what parts are being used. BEWARE - some places will buy the heads bare and throw on the cheapest parts they can with a poor or non-existent VJ and sell them as if they were the factory assembled heads or even better (and sometimes I guess they could be). eBay seelers are notorious for this.
Rich
Rich
oldschool
Feb 9, 2016 09:21 PM
