ls3 to 454
Old Oct 20, 2009 | 11:41 PM
restless@westne's Avatar
ls3 to 454
hi i have an ls3 A6 in a VE maloo ute
i would like to up grade it to 454 ci 1/ using as meney of the ls3 parts as posable
2/ a compleat 454 crate that will just drop in and hock up to my E38 ECM and sensors an A6
some advise on these options thanks
Old Oct 21, 2009 | 07:13 AM
Kraest's Avatar
Retired
You can't make an LS3 into a 454. There's no enough material there to bore due to the factory aluminum block being 4.060" with a max bore of 4.070" or so unless you sleeve it --- which is a bad idea unless you're building a racemotor.
The biggest you can go is pretty much 427, but that's using a 4.100" crank, which will probably be counter-productive since it will make the engine undersquare.
A 418 is about as big as you'd want to go with a LS3.
You can purchase a crate motor or longblock from one of our sponsors.
Mike
Old Oct 21, 2009 | 03:46 PM
Chrome383Z's Avatar
You can achieve 500RWHP with those motors N/A stock displacement. I'd do that and spray the **** out of it.
Then when it blows pick you up a 418.
D1SC would work nicely on it as well.
Only block i'm aware of that you can do a 454ci is a LSX block, and I believe even it is not recommended for any power adders. I'd have to do some digging to check that out for sure...
Jake Bialke
Sep 24, 2015 11:31 AM
geinsteder
Exhaust System
Apr 20, 2015 04:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BartonekDragRacing
West South Central
Nov 10, 2002 08:57 PM
