ORY? Knocks sounds from a stop under the car HELP
Old Sep 15, 2010 | 07:52 PM
2000 maroZ's Avatar
Exclamation ORY? Knocks sounds from a stop under the car HELP
First day with my exhaust slp loudmouth 2 ORY pipe.. Love it but one thing...when ever i make turn or when i step on it. theres a knock under the car . its loud too. (Couple knocks) I heard it can be the ORY because its not welded? theres 2 bolts and theres like a brace where it holds together. Does it have to be welded. Thanks so much guys
Old Sep 16, 2010 | 04:40 AM
97WS6SCharged's Avatar
Check the driver side of the Y pipe and see if it's really close to the floorboard brace. If it is then you can use a clamp and some rubber hose to soften the impact.
Old Sep 18, 2010 | 08:39 AM
Marc 85Z28's Avatar
Cheap fix: EGR/emissions hose and a hose clamp to hold it on the ORY where it contacts the body.
Proper fix: urethane motor mounts.
Old Sep 28, 2010 | 10:23 PM
2000 maroZ's Avatar
can i use some header wrap and just wrap it around? will that cause vibrations?
Old Sep 29, 2010 | 06:07 AM
AL SS590 M6's Avatar
Moderator
yes
no
fpete1992
Dec 11, 2014 03:51 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Lions3
Apr 11, 2003 10:55 AM
