400 HP on 87 Octane... 383 Stroker, is it worth it?
The ones I see at Texas Speed are about $2k, any cheaper than that? And if there are, are they just as reliable?
Anyway, I know to make power that most of it comes from your heads / cam setup, but are strokers worth investing in? I wanted to build a 400 HP low compression motor. I know stroking increases compression, but I was thinking to offset it with thicker head gaskets or using dished pistons
Or is there another way I should try to reach my goal?
Why 87 octane?
And if you're looking for a 383 stroker setup, you're going to spend a LOT more than $2000! You're better off sticking with the stock 346 or go to a 370/402/408. 383s rarely make enough power over a similar 346 to justify the cost.
How would you go about building a 370 though?
Let's assume you get 15 mpg out of that 383 and drive it 200 miles every week all year long.
200/15 = 13.33 gal per week
13.33x2.50 = $33.33/week = $1732.90 per year
13.33X2.97 = $39.59/week = $2058.69 per year
I fail to see the logic of building a $4000-5000 (you will end up spending about this much) a nice motor to be 87 octane specific in order to save $6.26/week or $325.79 per year. If you drive it less than that your delta will decrease significantly.
Iron 6.0 bored .030" over. They're inexpensive and make a nice forced induction foundation.
Again, building a performance engine around 87 octane is foolish at best. You'll spend alot of time and money to reach your goal, and you'll be disappointed in the end. The money it takes to build what you are looking for far outweighs the cost difference in 87 vs 93 octane. Additionally, the engine will need either lower than stock compression or reduced timing, which will make for a lazy engine. Trust us, building an 87 octance engine is a waste of time - which is why nobody else does it
I don't know if you have driven or rode in a full bolt-on / heads / cam / intake 346 or not but if not you need to try that first. These motors fairly maxed out will really get your attention. I would seriously consider this option before wasting the money on a new motor build and not supplying the right fuel. A nicely built 346 will rape a bigger cubed LS that does not have all the supporting mods. Also if you do all this and can only run 87 octane you and your motor are not going to like it. If you can't budget the fuel for the build then I would suggest waiting and not doing anything to the motor right now. Maybe put the money into a full suspension, rearend, sticky tires, etc.
Again, building a performance engine around 87 octane is foolish at best. You'll spend alot of time and money to reach your goal, and you'll be disappointed in the end. The money it takes to build what you are looking for far outweighs the cost difference in 87 vs 93 octane. Additionally, the engine will need either lower than stock compression or a really timing, which will make for a lazy engine. Trust us, building an 87 octance engine is a waste of time - which is why nobody else does it
. Okay, I'm convinced I'll run premium. Maybe I'll offset it with buying a manual trans.I don't know if you have driven or rode in a full bolt-on / heads / cam / intake 346 or not but if not you need to try that first. These motors fairly maxed out will really get your attention. I would seriously consider this option before wasting the money on a new motor build and not supplying the right fuel. A nicely built 346 will rape a bigger cubed LS that does not have all the supporting mods. Also if you do all this and can only run 87 octane you and your motor are not going to like it. If you can't budget the fuel for the build then I would suggest waiting and not doing anything to the motor right now. Maybe put the money into a full suspension, rearend, sticky tires, etc.
No. The LS3 is very different. First the 6.0L is a 364. It has a 4" bore. With a 4.030" bore and stock stroke of 3.622" it becomes a 370. The LS3 uses a 4.060" bore and the same stroke, to displace 376ci
Of course it can, as can the LQ9.
You can treat the Gen III iron blocks much like the old SBCs. You can go straight to a .060" overbore, but most don't. If something happens like a damaged piston, broken valve etc that scores the cylinder wall, or even just in need of a refresh, the block is trash. However, if you just go .030" over, you still have that extra .030" if you ever need it in the future. But if you don't care about things like that, that seeminly insignificant extra .030" will allow for the proper use of the square port LS3 head choices
That is a ton of miles. If you are driving 100+ miles per day, you may want to skip the motor build, and find a fuel effecient daily driver.
