Need electrical HELP!
Old Oct 1, 2010 | 04:44 PM
jared4brack's Avatar
So after driving my car couple times in the day, my last trip i made a 15min stop, turned car off, left my blinkers on. When i went to start it up it was dead. Just click! Guages are dim and only reading 9volts and acting like its dead. So i try quick jump, does nothing, guages still dim, acts like out of power, but windows work ok and lights seem to be bright. So checked battery with voltmeter while car in "on" position, 12.1volts while guage is still only reading around 9volts. I cant figure this thing out hopefully someone can point me in the right direction? (no corrosion on or around battery)
Old Oct 2, 2010 | 06:52 AM
rwb's Avatar
rwb
Check your starter relay and your ignition relay for proper voltage.
Old Oct 3, 2010 | 07:22 AM
AL SS590 M6's Avatar
Moderator
Did you unhook the battery cables from the battery and check for corrosion there?
Old Oct 3, 2010 | 10:47 AM
I have an optima dry cell, no corrosion what so ever.
Old Oct 4, 2010 | 07:19 AM
Moderator
There are other types of corrosion that can cause loss of voltage.
You didn't answer my question.
Old Oct 4, 2010 | 10:49 AM
oh sorry! thanks for your help guys. The cars sitting in parking lot so i went last night while stores closed took a look under the car. Snapped 2 motor mount bolts (one being battery to block ground) so problems been found... noow i guess for my next nightmare! removing to broken studs from block
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
