Head stud goes into block too far.
Old Oct 2, 2010 | 04:43 PM
pHEnomIC's Avatar
I have an ls2 im doing heads on and my builder used studs on the two shorter bolts on each head. I ordered a new set of bolts and they didnt have the short ones so i have to reuse the studs.
For some reason, one of them screws in the block too far. I cant get enough thread for my nut.
It seems to go in hand tight to the right height, but once i screw the nut, it threads the stud in farther. Is there anything I can do? I want to get this car running asap and I dont want to have to buy two new head bolt sets.
Only thing i can think of is maybe putting oil in the block threads to hope it wont keep screwing in or possibly use a thinner washer (grade 8 from hardware store).
Old Oct 3, 2010 | 07:28 AM
AL SS590 M6's Avatar
Moderator
You shouldn't mix fastner types on a head install. Order the proper bolt kit or stud kit.
Old Oct 20, 2010 | 12:16 AM
Air-Adam's Avatar
D1SC383LT4
Jan 26, 2015 01:41 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
