Need new engine
Old Mar 15, 2004 | 09:56 AM
BlueEyesBlackZ's Avatar
Need new engine
Blew a couple of rods or something.....need to decide what I'm doing by tomorrow. Would a LS6 engine fit into my 98 Z28? Would it be worth it or would it be better to just get a LS1 souped up? Anyone know how much we are talking? Anyone have any websites I can go to check on engines, prices, etc.?
Old Mar 15, 2004 | 10:13 AM
jbird's Avatar
LS6 should fit, I believe it's essentially, as far as dimensions and things, about the same as an LS1. Whether it will be worth it or not, well, that's for you to decide. Not sure how much it would run you, are you thinking of getting a used engine or a new one? New engine prices will be easier to find, because prices fluctuate on engines pulled from wrecks, but new engine prices aren't pretty so be forewarned. I would think that you might come out a little cheaper to get a used ls1 and build it up a bit, or get a used one, drop it in your car, then rebuild the one you have depending on what's wrong with it. That way you could keep your car running, and build the engine up as time and money passed. Used LS1's will be MUCH easier to find then the more or less Z06 specific LS6.
Old Mar 15, 2004 | 10:19 AM
Not interested in used or fixing up. I'm not a fixing up kinda guy so labor rates would kill me. I'm lookin for the baddest engine out there. Mostly lookin at horespower. I'm thinking I probably will have to do something to my rear end so I'm not spinning them at every intersection. So if you had to choose between a new ls6 or a new ls1 what would you choose? I'm thinking $5k.
Old Mar 15, 2004 | 11:28 AM
teke184's Avatar
new ls1 crate from jegs
or www.paceparts.com sells the ls6 crate motor...405hp
their site is down for maintenance otherwise i would post a link
Old Jul 22, 2004 | 01:00 AM
tombodad's Avatar
Re: Need new engine
hey i know this is an old post, but i was doing a search and I am in the same process as you, wondering about an ls swap into my 98 z28. Cheapest Ive founs new is 5,050 at gmpartsdirect.com. Just click on upgrades, then camaro. Have you found anything better?
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
