Questions ASP pulley
Old Mar 10, 2004 | 05:59 PM
bombd84's Avatar
I just ordered a ASP pulley from Speed inc. I know that I will need some new belts, but what is it I keep hearing about the crank bolt?? Does Speed Inc. tell you if an item is out of stock also?
Clint Smith
Old Mar 10, 2004 | 06:50 PM
CamaroGuy22's Avatar
I belive you need a new crank bolt when installing.
As for Speed inc.'s practices i dont know.
Old Mar 10, 2004 | 06:57 PM
bombd84's Avatar
Where can i get a new crank bolt, and what size/how much will it be??
Old Mar 10, 2004 | 08:12 PM
teke184's Avatar
that's where i got mine and i used the stock bolt...why would you need to change it?
just be prepared to fight with getting it off and back on and torqued to the 200 something Lbs of torque it requires...
the key is a long breaker bar and some pipe for the end!
Old Mar 10, 2004 | 08:19 PM
Some get a new bolt since if you mess that up it would throw the balance off. It is a torque to yield bolt. You can get the ARP crank pulley bolt and youll never have to replace it again.
Black Sunshine/ 00SS
Jul 24, 2002 11:35 PM
Jul 24, 2002 08:57 AM
Jul 22, 2002 09:58 AM
Jul 20, 2002 11:16 AM
Jul 19, 2002 07:40 AM
