should i be making more hp?
Old Mar 11, 2004 | 10:24 AM
z28spd's Avatar
mti stage II heads (2.055" on intake 1.60" on exhaust)
FLP L/T headers
MTI Lid
75MM MTI Throttle Body
MTI C1 Cam (duration intake and exhaust 222, Lift intake .566 exhaust .566, lobe sep 112)
Borla Exhaust (cats)
MTI custom PCM tuning
making 381RWHP should i be making more?
2000 camaro z28
Old Mar 11, 2004 | 10:53 AM
SSCamaro99_3's Avatar
I would think. I am making 381 with a Hotcam, no heads, and untuned.
Old Mar 11, 2004 | 01:39 PM
Gold Z's Avatar
Considering the specs on your cam, your hp sounds about right. Heads won't make much difference with mild cams. Also you are running through cats and are not using an LS6 intake. But I'll bet your car drives as easy as a stocker, will pass emmision testing, still gets great gas mileage, starts and idles easy, and runs great........it sounds like a good combination to me.
Old Mar 11, 2004 | 03:32 PM
Omega9's Avatar
Thumbs up
Sounds right to me. Can't wait to get my new cam Thunder Racing 224-112. Along with long tubes, ASP pulley and LS1Edit I should be making around 390rwhp or more. Snake meat is beginning to look very appetizing
Old Mar 11, 2004 | 11:32 PM
2ktransam's Avatar
Was this on a dynojet or mustang dyno. Dynojet normaly will give higher numbers. I have basicaly the same setup and I pulled 408 corrected to the wheels and 416 uncorrected on a dynojet. Did you have your exhaust open or closed? I have flowmasters on my car and a cutout. With the cutout closed I pulled 383 hp but when we opened the cutout we were suprised with the 408. Make sure you are running open exhaust.
Old Mar 11, 2004 | 11:34 PM
2ktransam's Avatar
Oh yeh, I also agree with Goldz. You need to get a ls6 intake if you do not have one.
Old Mar 12, 2004 | 01:12 AM
LSs1Power's Avatar
If u are running the cats on the FLP's take them out and u will see some gains there. Look at sig before and after the cats on the FLP's. LS6 intake manifold will help alot too. Although, i think ur car should be making close to 400rwhp even with the small cam.
Old Mar 12, 2004 | 06:50 AM
robb4964's Avatar
Re: should i be making more hp?
FLP L/T headers
MTI Lid
2000 camaro z28
That cam and good tuning alone should net you that kind of HP . There is definitly something up with those numbers .
Old Mar 12, 2004 | 09:03 AM
z28spd's Avatar
what cam should i get that would make the most rwhp. what kind of hp gains should u see from that kind of cam. I want a stout cam. Should i get a custom grind?
Old Mar 12, 2004 | 10:36 AM
LSs1Power's Avatar
Depends on what u want. Are u planning to run NOS or Boost? Are u going to keep ur car N/A? Do u mind if the car lopes or do u want a smooth idle? Do u want to rev above 6K to make the power or u want it before 6K? If u want to go crazy, i would go with GX5-2 on 110-111LSA. U will make crazy power with that cam, but u will need to drill a hole on the TB and good tunning.
Old Mar 12, 2004 | 03:04 PM
z28spd's Avatar
i am not planning on running boost or spray. keeping it n/a. dont really car about the idle, and w/e rev makes the best power
Old Mar 12, 2004 | 03:35 PM
LSs1Power's Avatar
Then go with either the LG G5X-2 with 111LSA or the new TR cam that made 450rwhp with stock heads.
Old Mar 12, 2004 | 03:39 PM
psychocabbage's Avatar
FLP L/T headers
MTI Lid
2000 camaro z28
MTI was the first problem there.. should ask around.. many people here in Houston do not trust MTI.. Sure some do but I know way too many that dont and that MTI has done wrong..
I wont even dyno at their shop since I have known of them doctoring their dyno numbers..
anyways... I would think you could be making more with your mods but the MTI part messes with the facts IMO... Maybe get another dyno done at another shop...
Or get to the track and see what it does..
Victor Lamb
Aug 26, 2017 02:52 PM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
