how man o2 sensors does 00 ta have?
Old Mar 16, 2004 | 05:58 PM
bluecmaro96's Avatar
ok here will be my exhaust setup
jet hot longtubes- stock cats hollowed out- 2.5" x pipe- 2.5" bullets, then either turndowns or over the axle. ok now i will need 2 o2 extensions right? what length should i get? how many simms do i need? anything else i need? would my stock cats just get welded to the collector of the headers? since the jethots dont have flanges?
Old Mar 17, 2004 | 06:56 AM
teke184's Avatar
if you are running cats...you won't need sims
there are 4 sensors, two in front of the cats...vital to the engine's air/fuel monitoring system. and 2 after the cats to monitor the efficiency of the cats. if the cats are gone, those sensors will trip a code, but the code does NOTHING for performance...just the nuesence of the SES.
tech support on thunder racing or tbyrne should be able to give you the proper length extension.
how they are attached is up to you. i would suggest welding a 3" to 2.5" reducer to the cats, then the reducer will slip into the collector...and run the rest of the exhaust behind the cats...Xpipe etc
Old Mar 19, 2004 | 03:03 PM
adam_3's Avatar
Just a bit off topic. I thought that the rear o2 sensors were supposed to trip and code if the cats are hollowed out, it would make sense. But I hollowed out my passenger side cat the other day because it was rattling really bad. Before I hollowed the cat I had a check engine light, after I hollowed it out the light turned off. Any insight? I thought that was really weird.
sleeperZ96BT
Sep 9, 2015 08:28 AM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
