Water pump & Alternator removal & install write up needed.
alternator is pretty straight forward, just a bit cramped
as for the waterpump, i think www.ls1howto.com or www.ls1camaro.net has an install guide for an electric wp on the ls1. that should give you the general idea of how to pull the pump.
I need the part number for that single wire connector. The dealer I went to couldn't come up with that part. Funny cuz they tried to look in a parts book since the system only came up with a four wire connector and the book only went up to 96 models. Anyway do I need this dam thing or can I just get the four wire connector? I do need the four wire connector for sure, but the single one is in question now.
As you can see I am leaking PWR steering fluid onto the alternator. I took off the the 4 wire connector and red Pwr steering fluid was inside. My guess is that the leaking steering fluid fried the wires.
The arrows are pointing to the connection in question.
http://images.cardomain.com/member_i...8_299_full.gif
