does anyone who has jethot longtubes an y pipe not have the y pipe hitting floor pan
Old Mar 16, 2004 | 07:14 PM
bluecmaro96's Avatar
i here some have problems with the y pipe hitting the bottom of the car, i dont wantthis to happen because it may cause false knock, how can i stop this? and i hear the car will run rich with longtubes, is there anyone i can send my pcm to to just get it adjusted for the headers that isnt insanely expensive, again sorry for being a pain, i just dont wanna buy something anymore like i did with my v6 w/o fully researching
Old Mar 17, 2004 | 06:53 AM
teke184's Avatar
no appology needed.
as for tuning...i think you're limited to places like www.pcmforless.com , madwolf, or tbyrne and the like.
don't know about the clearance probllem with longtubes (will know soon). but when i installed my bassani ORP on my manifolds the pipe hit the frame (brace under driver floorboard) when i would launch or when i would really punch it in 1st or 2nd gear....whenever the engine would really twist under torque.
i cured it by installing poly motor mounts...now the motor hardly moves when reved and the pipe doesn't come close to the frame.
i have pics of the spot on my webpage in the sig...page 2
Old Mar 17, 2004 | 01:28 PM
jv_Z28's Avatar
I have LT's and a 3" y and my pipe hits the bottom of the car when ever I get on it, you can do polly motor mounts. Ive tried to get some kind of mount put on from an exhaust place but its gonna cost a lot because its so far from any place to put a flexing polly or rubber mount. But it can be done- its just a custom job
Old Mar 17, 2004 | 01:54 PM
SSCamaro99_3's Avatar
My Jet-Hot Y-pipe didn't hit the floor, but if I left it in gear during deceleration it would rub. When I sold it it had one little rub spot on it. You could always put radiator hose between the pipe and the frame. Cheesy but effective.
Old Mar 17, 2004 | 07:07 PM
1BADAIR's Avatar
Mine also hit. I installed a Prothane motor mount on the drivers side to fix the problem.
Old Mar 18, 2004 | 01:24 PM
Y2K2Sierra's Avatar
I installed a Prothane motor mount on the drivers side at the same time that I was installing the headers and never had a hitting problem.
Chris
Old Mar 21, 2004 | 02:06 PM
chris at jethot told me the newer ones wont hit because they redesigned them asgain
Old Mar 22, 2004 | 12:06 AM
QCKZ28's Avatar
we just put jet hot longtubes my friend 02 ls1, install was easy, but a primary touched the k-member on the driver's side, he has a custom y pipe that doesnt bang at all with stock motor mounts....
HectorM52
Jul 30, 2017 11:46 AM
mattstrike
Mar 11, 2015 07:33 PM
dale3in98
Feb 14, 2015 12:18 PM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
