how much ground clearance with lanes tru duals?
Old Mar 7, 2004 | 10:44 PM
bluecmaro96's Avatar
and what should i get, 2.5" or 3" true duals? is there alot less ground clearance with these than a normal cat back system? any banging from the true duals on the bottom of the car? if i order from him will i have to bend any pipes or are they already bent perfectly so i can just do a install like i would do with a normal cat back? thanks what longyubes are best for true duals?
Old Mar 8, 2004 | 01:39 AM
Gold Z's Avatar
Ground clearance is excellent. They tuck up really nice. I have no banging at all. His systems are fully bent and welded. You will have to mount a couple of hangers but that's about it. Be forewarned.....they are LOUD! Give Lane or Mike a call withyour questions. Here are pics of their systems...
http://www.laneswheels.com/custom_duals.html
Old Mar 10, 2004 | 08:07 PM
he wont answer my emails, i know he is busy but i would ike a price does he also make true duals for someone who has to keep their cats due to emmisions? can he go over the axle? in your opinion would i get close to the same hp with slp loudmouth as i would true duals? would slp longtubes work with true duals?
Old Mar 10, 2004 | 08:48 PM
Florida_Z28_Boy's Avatar
I've heard the sound clips and they all sound really nice! If you want a quieter, mellower tone, you could pry have Magnapacks put on there.
As for the over the axle deal, many people with duals have the pipes over the axle and Lane's would PROBABLY do this for you.
Old Mar 11, 2004 | 09:05 PM
would your hp or et be worse if you went over the axle rather than dumps before? i hope over the axle would be about the same et and hp as dumping it
Old Mar 12, 2004 | 05:38 AM
Going over the axle shouldn't make any difference in power or E.Ts unless it's poorly down with many turns and kinks.
Also dumping before the axle tends to kick up alot of dirt and set grass on fire take that from personal experience with a friends 1995 Mustang GT that had dumps before the axle.
Old Mar 12, 2004 | 08:45 AM
MikeyG's Avatar
Those systems look really nice. What's pricing like on those?
Old Mar 12, 2004 | 04:52 PM
i emailed lane but got no response
marlar98
Sep 19, 2015 07:53 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
92_RS_305
Sep 8, 2015 07:47 PM
Catmaigne
Jul 14, 2015 05:17 PM
