want true duals but am afraid its much louder than loudmouth opinons please.
if i had true duals, turndowns with jethot longtubes would that be way louder than the longtubes and loudmouth? will the true duals be more annoying than the loudmouth? sorry for bein a pain thanks
another thing to consider is that the interior resonance may be a bit annoying on any long trips with the duals. this is because the sound will reverberate under the car a bit. where the LM will push the sound back and therefore not bounce off the pavement and the underbody (causing reverb).
duals will sound better in general though
i heard that if i cut the resonator out of teh lm and weld in a bullet that will take away some rasp? i think i may just go with the lm with bullet and maybe later down the road go with true duals, i dont think that ill gain a significant amount of et with the true duals over lm with a mildly modded car.
BlueCamaro...
To reduce interior sound levels...you'll wanna run the pipes out the back (more cost though) or have the turndowns pointed towards the sides of the car rather than at the ground. This prevents the sounds from bouncing off the payment, as already said, and also doesn't allow the turndowns to kick up dust onto your car, and I PROMISE you'll notice the excess dust that ends up on your car with turndowns.
I also have been told a "X" pipe gives you a mellower sound than a "H" pipe.
Bullet mufflers are pretty loud but not really raspy on true duals. Or you could do like I want and get Magnapacks I hear they sound great.
P.S Every true dual 4th gen I've heard...both in person and from sound clips...sounds BADASS!
Those Magnapacks are crap. Just expensive glass packs.
Did you notice the "All Universal MagnaPacks have a 2.25" Core." at the bottom of their tables? That means you can run 2.5" or 3" inlet/outlet and still get the nice restriction of 2.25" pipes. Thats a 23" long bottle neck. Ya, thats gotta be good for performance.
LMAO!!
yeah right!
There are headers with smog provisions, but they are not smog legal since it forces the cats to be moved and that is not permitted.
and.........True Duals dominate all!
(mine are in the mail right now
yeah right!
[Electronics/Car Audio] NavTool Beta Testers Wanted
navtool.com
Sep 24, 2015 03:30 PM
