PCV valve
Old Mar 22, 2004 | 12:06 PM
Knowklew's Avatar
PCV valve
How often should i change this?
Where is it located on the LS1?
Old Mar 22, 2004 | 03:57 PM
steelerfan's Avatar
It's not an expensive part & it's easy to get to & do so evey 10,000 - 20,000 should be good.For install location & instructions check out www.installuniversity.com lots of good info there for you.I've found it very helpful
Old Mar 22, 2004 | 08:54 PM
Greed4Speed's Avatar
The PCV is nothing but a 1 way check valve. It really only needs to be changed when it isn't funtioning properly. Its simple to check it too.
Old Mar 23, 2004 | 01:58 AM
andrewz28's Avatar
i change mine in the spring each year. for $3 it's worth it to replace it. if i waited to change it every 10-20,000 miles i would be changing it every 3-4 years now which is way too long.
14
Aug 11, 2015 12:03 PM
surreybrad
Aug 10, 2015 09:34 AM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
