air pump removal
Old Mar 8, 2004 | 08:30 AM
jasonss's Avatar
air pump removal
how hard is it to remove the air pump, and what is the best way to do it
Old Mar 8, 2004 | 09:30 AM
2001NBMZ28's Avatar
This artiicle explains how to do it - looks easy.
http://www.ls1camaro.net/sections.ph...ticle&artid=70
Old Mar 8, 2004 | 12:01 PM
teke184's Avatar
why do ya wanna remove it? just for looks?
you will get an SES light if you pull the pump and don't have it programmed off the computer.
Old Mar 8, 2004 | 12:34 PM
2001NBMZ28's Avatar
Good point - I should've mentioned that. That site says you won't get any codes, but may depend on the year. I pulled my air pump fuse to see what would happen and immediately threw a code. I'm going to wait until I get another tune before I remove mine.
Old Mar 8, 2004 | 02:56 PM
jasonss's Avatar
i got ls1 edit on they way so that will take care of the code, i got mac mid lengths headers on my car and i'm tired of hearing the air check valves ticking, so they are gone, when edit gets here
Old Mar 8, 2004 | 04:02 PM
Dark Angel's Avatar
It's very easy to pull. The pump and be pulled from the underside of the car, then pull the hosing and then the tubes going into the manifolds. You will need to block a vacumn line if the pull one of the solenoids.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
