tire size
Old Mar 8, 2004 | 08:00 PM
camaronewbiess's Avatar
tire size
what is the largest width wheel you can put on the 99 stock camaro ss rims. I have 275s now and was wondering if 285 or higher would work?? thanks.
Old Mar 8, 2004 | 08:32 PM
alteregoss2000's Avatar
I have 285's on my 2000 ss.
Old Mar 8, 2004 | 11:11 PM
and the 2000 ss came with the same rims i assume??
Old Mar 8, 2004 | 11:13 PM
99blackSS's Avatar
Yes.
Any bigger then 275 on the SS rims doesn't look quite right and has no benefit other then the tires costing more. The biggest I have seen on a SS rim is 315s.
Old Mar 9, 2004 | 12:05 AM
BlownLS1's Avatar
True True
On my stock SS rims I have 275 35 17 Nitto 555R. They look fine..
No point of paying more money when your rim setup dont look good on your car.
Old Mar 12, 2004 | 01:39 AM
Zerocool's Avatar
are my Good Year F1's good tires? they are new.. how do they rate as a tire overall?
Old Mar 14, 2004 | 10:04 PM
StealthZ28's Avatar
I have 245-50-ZR16 on my stock wheels on my '98Z28 and to me they look kinda small. I also am wanting to go with something wider and bigger but I am not sure what size tire the stock wheels can mount. Eventually I am going to purchase 17x9.5 American Racing S202 Megnetallic 2-piece painted wheels. I liked the wheels that are mounted on the Intimidator SS and think it would look really sharp on my '98 Z28. Could someone tell me what size and width tire I sould go with on stock rims? Thanks.
Old Mar 14, 2004 | 11:15 PM
JaysGone's Avatar
StealthZ28 if you go with a 17 inch rim and the stock size for a SS tire 275x40x17. It will be the same overall diameter as the 245x50x16. But they will have about a 1 inch wider footprint. In other words in my opinion unless you autoX there is no real advantage other then wheel style change switching to a 17 inch rim
Old Mar 15, 2004 | 10:05 AM
StealthZ28's Avatar
So 275-40-17 tires will fit my stock rims? I will eventually purchase 17x9.5 rims in the future. I am going for style. Plans for performace mods are happening right now. A GMMG cat-back is being installed right now, SLP lid, SLP headers by this Fall. And my Xenon ground effects are going to be re-painted this Spring. But like I said, my stock tires and rims just look kinda small. And I want to get wider 17" tires with the rims I mentioned before. Thanks.
Old Mar 15, 2004 | 02:00 PM
1stls1's Avatar
On a 17/9.5 rim,will 285/35/17 fit all around w/ 1.5" lowering springs w/out rub?
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
