Underdrive pulleys
Old Mar 10, 2004 | 03:05 PM
SLPZ28's Avatar
Underdrive pulleys
I know for most bolt on's underdrives don't do much for the cost of the pulley, but someone told me with a cam you could really pick up 10-15 RWHP what you guys think?
Old Mar 10, 2004 | 05:39 PM
teke184's Avatar
i can't see why it would make a difference, it's not like the engine is spinning any faster...
the ud pulley just slows down the accessories, meaning less drag on the engine...what does a cam have to do with that?
i'd say it's worth 10hp across the rpm band...maybe not peak...but not 15hp.
i noticed it reved up a bit faster when i put my ASP unit on
Old Mar 10, 2004 | 08:02 PM
1stls1's Avatar
I have hear of using a cam and alt ud pully system to keep everything in check?I am thinking of going w/ ud as well please any info or kit that has been used would be of great help!!
Old Mar 11, 2004 | 12:53 AM
coogsLS1's Avatar
I have heard that if you put a new one on the alternator that you can see some serious charging and electronic power loss. This might not be true because it was a 95 thunderbird that it was put on but I could see it happening.
Old Mar 11, 2004 | 06:20 AM
teke184's Avatar
i have not got any ALT pulley installed, and i can notice absolutely no difference in the charging of the car.
now if you have a big stereo something that draws alot of power, you may notice it more.
Old Mar 11, 2004 | 08:01 AM
SLPZ28's Avatar
Well I didn't think so. But a friend of mine thought you pick up more HP with a cam an a pulley the a pulley and just bolt ons.
Old Mar 11, 2004 | 08:26 AM
Antz97ZNJ's Avatar
dont waste your money, believe me you wont see 10-15 rwhp, thats what the companies use to say way back when they 1st came out in the LT1's...maybe 5 hp at best, save your money for some long tubes
Old Mar 11, 2004 | 08:50 AM
CamaroGuy22's Avatar
On an LT1 you will be lucky to see 1 rwhp. On an LS1 you will see 6-7 rwhp.
Old Mar 12, 2004 | 08:02 PM
1stls1's Avatar
It is not onley just what HP you gain, but also how fast you get up to RPM.
Old Mar 12, 2004 | 09:42 PM
ULTIMTEORANGESS's Avatar
its a worthwhile cost efficent mod thats proven.ask the guys with fast ls1s if they have this part.ill bet they all do.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
