Steering weird with locker engaged?
Old Oct 28, 2003 | 10:26 AM
Rodrigues's Avatar
When im on the highway or street and I give it throttle so the detroit locker engages, my car wants to go right slightly and I have to constantly counter steer it. Any ideas on what might cause this?
Old Oct 28, 2003 | 11:00 AM
rskrause's Avatar
Moderator
Re: Steering weird with locker engaged?
It's normal with a locked rear end and is a form of "torque steer". Lockers cause torque steer negative to the direction the vehicle is trying to turn. In other words, they try to steer the vehicle straight in a turn (understeer). When you are trying to accelerate in a straight line, the torque twists the rear axle around the vertical axis and tries to push the car to the right.
Rich Krause
Old Oct 28, 2003 | 11:06 AM
Blake's Z's Avatar
Check to make shure the rear tires have the same pressure.It sounds like you may have a low tire if it pulls to the same side every time the locker engauges.
Old Oct 28, 2003 | 01:37 PM
Z28SORR's Avatar
You may also want to have your rear axle alignment checked.
Old Oct 28, 2003 | 03:24 PM
anaik's Avatar
I thought the Detroit Locker was always engaged going in a straight line, and disengaged when making a turn.
Old Oct 28, 2003 | 03:53 PM
Rodrigues's Avatar
It is, im talking about going strait down the highway and my car wants to pull right at constant throttle....
Nayr
Mar 3, 2023 08:34 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 18, 2015 07:08 AM
alphaauto
Jul 26, 2015 04:40 PM
