cant find blinker fluid at autozone (big thinkers inside)
Old Nov 1, 2003 | 11:56 AM
stlws6's Avatar
just kidding i need help bad my trans wont shift. it can only be shifted manually i only have 1 to 2. the selonoids are all new even my presurre control selonoids. my data master file says that (which i can email you all you have to do is email me) the force motor ref amps moves around .16 to 1.07 and my forcemotor act amp is 0.0 ??? the shift selonoids all are getting power but the presurre control solnoid was reading like .1 volts for like a split second every three seconds, but that was with the car on but not running. the solnoids a and b are throwing codes so i think the presurre control is not getting power. my email is bhunterx@charter.net
Old Nov 1, 2003 | 12:04 PM
OldSStroker's Avatar
I think you might get more transmission help in the "Driveline" forum. A bunch of trans guys hang out there.
Good luck.
BTW, I use Visine for my blinkers.
Old Nov 1, 2003 | 01:26 PM
gasnmyveins's Avatar
Blinker fluid? I think it's in the aisle next to the metric crescent wrenches and calibrated hammers, with the flight line and rotor wash. Didn't know they now service aircraft, did you? If they don't have it in stock, you can get them to order it with the I D ten T form.
Old Nov 1, 2003 | 04:13 PM
kmook's Avatar
Advanced Tech Moderator
Lets try this in the DriveTrain Forum as suggested above.
Moving, Thanks.
captcorvette
Mar 7, 2015 12:37 PM
Briah.hood
Feb 17, 2015 02:10 PM
rjc1629
Jan 27, 2015 10:46 AM
Hurin
Dec 13, 2014 07:38 PM
squarehead
Nov 21, 2014 08:02 PM
