wheel bearing help
Old Nov 5, 2003 | 04:06 PM
tommyb's Avatar
wheel bearing help
I'm changing my front right wheel bearing, but can't get the hub off. I removed all 4 bolts, and hit the living bejeeses out of it. It just won't come off. HELLLLPPPP!!!!!
'97
Old Nov 6, 2003 | 10:44 PM
Use some penetrant (PB Blaster or similar) on it. It is a tight fit in the knuckle and if there is a lot of corrosion, it can be hard to remove. After you get it out, clean up the area before you put the new one back on.
grabbem88
20
Dec 27, 2015 07:42 PM
akwa
Apr 5, 2015 05:09 PM
warmeck
Mar 8, 2015 08:01 PM
