Car is lopsided after axle swap
Old Oct 18, 2003 | 01:48 AM
Twice The Fun's Avatar
Question Car is lopsided after axle swap
Had the dealership put in a new axle under warranty the other day, and now the car is higher on the side the axle was put it. What could they have done wrong?? any thoughts...
Old Oct 19, 2003 | 11:13 AM
OldSStroker's Avatar
Maybe the spring isn't seated properly, or they tightened the lower control arm attaching bolts on that side with the axle drooped instead of at ride height. That puts a torque in the bushing and it acts like an additional spring. Take it back.
My $.02
Old Oct 26, 2003 | 07:19 PM
or should i just have TSP fix it and add lowering springs and bilstein shocks??
Old Oct 26, 2003 | 10:33 PM
Rodrigues's Avatar
the spring probably wasnt seated proporly
Old Oct 26, 2003 | 11:35 PM
thanks for the replies, a friend and i are getting under there 2morrow and gonna get this thing back to even...
Old Oct 27, 2003 | 08:18 PM
Garage Inc.'s Avatar
How'd you make out?
Old Oct 29, 2003 | 12:22 AM
just as clueless as b4.....everything is the same on both sides as far as looks.....my friend thought maybe the left out something while putting it back together...no such luck
i am clueless...and i am beginning to think either it was this way b4 the axle swap, and i never noticed it....doubt that.....or maybe a spring is giving out. BMR springs go in asap!!!
Old Oct 29, 2003 | 10:40 PM
Are both springs sitting in the perches the same way? The open end at the bottom of the coil should face to the front of the car.
Old Oct 30, 2003 | 12:46 AM
i didnt check that...how much difference in height could that cause...its about 3/4"
Old Oct 30, 2003 | 12:55 PM
You did loosen then retighten the bolts thru the control arm bushings while the car was at ride height, right? If not, you'll not find the "preloaded" bushing, which is still my best candidate.
Old Oct 30, 2003 | 02:55 PM
havent tried that either.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
cmdeshon
Dec 27, 2014 10:06 AM
cmdeshon
Dec 12, 2014 10:51 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
