Rear fluid
Old Nov 7, 2003 | 11:14 AM
BigBlue95Z's Avatar
Rear fluid
What kind of fluid is needed for the rear? Should i go synthetic?? Anything else i'm gonna need besides: gasket, limited slip additive, and fluid?? Need to know ASAP!!! Thanks a bunch!!!
Jason
Old Nov 7, 2003 | 11:32 AM
Fast Caddie's Avatar
That's pretty much it. If you go full synthetic you won't need the additive.... I went full syn. and don't have any noises coming from the rear. When i got the car it had regular gear oil in it and it whined constantly. HTHs
Old Nov 7, 2003 | 11:40 AM
BigBlue95Z's Avatar
What weight synthetic fluid??
Old Nov 7, 2003 | 03:00 PM
Hmmm.... i can't recall the exact weight, 80W-90(?) I think. Anyway, I just used the same weight as OEM in synthetic form.
Old Nov 7, 2003 | 06:39 PM
rskrause's Avatar
Moderator
If you have clutch type posi DO NOT use synthetic. Eaton, for example, specifically states that only mineral based lubricants should be used.
I use regular old dyno juice in mine.
Rich Krause
Old Nov 7, 2003 | 07:29 PM
Brandon 95 Z28's Avatar
Yeah I use regular GM non-synthetic 80W-90 and a bottle of additive in mine.
Brandon
Old Nov 8, 2003 | 07:14 AM
jkipp84's Avatar
I used GM oil, additive, and gasket this last time (after gear swap 200 mile change). Don't forget to pick up the funky tube thing at Autozone for getting the fluid in there. It's like $3 - well worth it..
CGM2010CAMARO
Apr 7, 2015 07:44 PM
warmeck
Mar 16, 2015 07:02 AM
WildRidez
Feb 23, 2015 07:24 PM
alex5366
Feb 17, 2015 10:43 PM
FredM
Dec 18, 2014 01:40 PM
