rear end noise
Old Oct 18, 2003 | 07:50 PM
gfrankel's Avatar
rear end noise
I have a 99 TA. I have noticed that the rear end is making a "woo,woo,woo" type of sound, at any constant speed. What could be the problem? Any suggestion would be helpful.
Old Oct 18, 2003 | 08:09 PM
DS01Z28's Avatar
G,
Could be a couple of things:
1. pinion gears &/or rear bearings/seals; or
2. (and this is a long shot)... did you recently get different rims on the car? Reason I ask is because one time I got new rims on a "tuner" I used to have and they made a constant "whoooo"-loke humming noise, particularly noticeable at speeds 60mph and greater. Does your car make this noise at all speeds? (ie, 20? 30? 40? 50? 60? and more?).
Or, a couple final possibilities that I can think of:
3. axle slippage (are the splines on the axle shot? Do you or the previous owner-if applicaable- spin the tires alot?); and
4. are you sure the noise is from the rear end and not the tranny? could it be flywheel or clutch slippage???
If you're running OEM rear gears that have never been changed, look into changing the rear end lubricant. Does the rear end leak?
Check the tranny fluid. Is it low? Has either the rear end oil or the tranny fluid ever been flushed and changed? How many miles are on your car? Original tranny? or rebuilt? or aftermarket bolt-in?
Could use a bit more info, but I'd start with the fluids first (easiest and cheapest), then progress to having the rear end and tranny checked.
Daryl
Old Oct 19, 2003 | 02:24 AM
whoa guy's Avatar
when i put 3.73 gears in my old Z...they whined on the highway. they were used. quite common if they are used. i would take my foot off the gas and it would stop. i got used to tit.
Old Oct 20, 2003 | 07:56 AM
camarokid167's Avatar
I have the same thing, changed the rear end lubricant and it still does it, never changed the gears or the rims on the car.
Old Oct 20, 2003 | 09:07 AM
DS01Z28's Avatar
The only other thing I can think of is the tread on the tires. As I mentioned earlier, when I had the "tuner" car and got new rims, I also got Nitto 555 Extreme 17's put on. The tire dealer said they might be contributing to the road noise (a low drone kind of sound).
Daryl
Old Oct 20, 2003 | 03:04 PM
nope, just got new yokahomas and the noise was there before I got my new tires and is still there now with my new tires
Old Oct 21, 2003 | 09:26 AM
Chris 94Z A4's Avatar
Wink
Whistle tip goes WOO! Sorry, I just couldn't help it.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
