Considering trading my 12 bolt for a 10 bolt. Am I crazy?
Obviously the title will warrant an explaination.
My car currently has a stock 12 bolt with the original open differential and as far as I can tell 3.23-3.36 gears.
I just bought a TH400 from a guy I know who runs a shop and has built numerous drag cars over the years, and he has offered me a trade. He has a '70 Chevelle with a 10 bolt, and he will install whatever gears I choose and a new posi if I trade him my stock 12 bolt for it. I'll have to get a little more info on it, but I believe he would ask for no additional money or at the least, very little in addition to the trade.
Now I know the 10 bolt would be more than adequate with my current, anemic 350. But of course I have intentions of greatly improving my engine eventually, possibly even going to a big block (not too likely, but still possible). However, this trade could save me ALOT of money over doing the same things to my 12 bolt. Would it be worth it?
I just bought a TH400 from a guy I know who runs a shop and has built numerous drag cars over the years, and he has offered me a trade. He has a '70 Chevelle with a 10 bolt, and he will install whatever gears I choose and a new posi if I trade him my stock 12 bolt for it. I'll have to get a little more info on it, but I believe he would ask for no additional money or at the least, very little in addition to the trade. Now I know the 10 bolt would be more than adequate with my current, anemic 350. But of course I have intentions of greatly improving my engine eventually, possibly even going to a big block (not too likely, but still possible). However, this trade could save me ALOT of money over doing the same things to my 12 bolt. Would it be worth it?
First of all I'm guessing you have a 1st or 2nd generation car. If not ...well we won't go there
...but anyway a Chevelle rear will not work in a Camaro. Back then the Camaros were leaf springs cars vs Chevelle that was coil...not to mention the Chevelle rear is a tad wider. Could you make it work...yes but its not worth it. Get one made for the car! the twelve bolt is MUCH stronger than the ten...so if your going to upgrade one do the twelve bolt it will pay off down the road especially if you go the big block route. My past DRAG cars were a 69Z with a 468 big block and a 70 Chevelle SS 454 car....hope this helps.
Yeah, no Camaro. The rearend should swap with little or no trouble. I'm pretty sure a built ten bolt will hold up to the puny power of my small block.
I talked to the guy Friday, and I think we're going to swap around Christmas.
Originally posted by menlatin
But if you can, get an eaton posi.
A well built 10 bolt from the 70's can take a lot of abuse and can stand up to well over 500 hp with the proper modifications. These rears in stock form will typically survive quite easily into the mid 400 hp range. Unlike the puny 10 bolts of the 3rd and 4th gen f-bodies, the units that went into 1st and 2nd gen f-bodies have an 8.5" ring gear. These rear ends have survived 9 second 1/4 mile runs.
Make sure that you are getting an 8.5" version of the 10 bolt. I cannot say for certain what vehicles to avoid but there was an 8.2" version that should be avoided with any type of anticipated buildup.
Steve
Steve
Thanks for the advice, guys.
If I ever decide to go to a big block, I'll probably get a pre-built 12-bolt or Ford 9 inch. At any rate, I doubt I'll be making enough power to hurt the 10 bolt for quite some time!
Now I just have to decide between 3.90s and 4.10s....
Victor Lamb
Aug 26, 2017 02:52 PM
ChrisFrez
Jan 11, 2015 03:47 PM
