9" moser
Old Oct 26, 2003 | 07:20 AM
97WRAITH's Avatar
9" moser
A guy I work with has a couple of 9" ford center sections and said I can have them. My question is will it bolt right up to a 9" Moser. Thanks.
Rob.
Old Oct 27, 2003 | 12:06 PM
anaik's Avatar
They should. I don't think the center section is modified for the F-body conversion. It would also depend on what spline axles the spider gears would take. That is if the center sections came with internals.
Old Oct 27, 2003 | 06:19 PM
mls48341's Avatar
they would also need to have the same size bearings.
Old Oct 27, 2003 | 09:11 PM
97WRAITH's Avatar
Thanks! I not too worried about the splines or bearings as I am having it machined to accept 33 spline axles and will be buying new bearings. My main concern is the screw pattern and physically the same shape, size, etc...
Rob.
Old Oct 31, 2003 | 09:19 PM
97WRAITH's Avatar
Anyone else have any good info about this?
Thanks!
Rob.
Old Nov 1, 2003 | 05:26 PM
Rodrigues's Avatar
ANY ford 9" centersection will bolt to a moser 9" f body drop in rear end. The big question is will the aftermarket axles fit through the small ford bearings. Also, is it really worth it to try and make a stock ford 9" centersection work? They used crappy pinion bearings and the physical case can't hold the pinion very well of the stock ford centersections.
Old Nov 1, 2003 | 06:56 PM
97WRAITH's Avatar
Can't I just get Hi performance bearings for it and the center section is free so what isn't worth it?
Old Nov 1, 2003 | 07:28 PM
Rodrigues's Avatar
spending as much as you will be on the housing etc to have a stock ford center section. The housing is where the weakness is, not the bearings.
Old Nov 1, 2003 | 09:33 PM
97WRAITH's Avatar
Well it will definitley be stronger then a 10 bolt. The free center section will have to do for now.
Rob.
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
ddr698
Jan 9, 2015 10:05 AM
Shawn's Dad
West South Central
Sep 12, 2002 09:11 PM
Shawn's Dad
West South Central
Sep 1, 2002 08:32 AM
