which driveshaft fits?
Searched around the board and concluded that an LS1 or 1LE aluminum driveshafts will bolt up to my '95 TransAm M6.
Now, is the 4th gen 1LE aluminum driveshaft the same one as the 3rd gen optioned aluminum driveshafts? Bolt right up with zero modifications?
Also - what are the th350 aluminum driveshafts? Will these also work?
Thanks a lot | college student on a budget therefore making doubly sure I get the right one
Re: which driveshaft fits?
-Rippin
Dave
To the best of my knowledge Yes it will fit. Im pretty sure that all the drive shafts were pretty much the same lenght. I just sold my buddy an aluminum d/s for his 98Z28. The drive shaft was out of an 88 GTA. It works fine. But his car is an A4 car that originally had 2.73's. But I belive that the M6 and A4 drive shafts are the same. I hope this helps.
Jeremy
Jeremy
Well man I can pretty much confirm it. I just done an A4 to T56 swap and I used the A4 drive shaft in the T56 so they must be the same. And an 88GTA drive shaft in a 98 Z28 proves that there is no difference from a 3rd to 4th gen other than diameter. The 3rd gen shaft is 3 inches in diameter and the 4th gen is 4 inches I belive. I hope this helps too.
thanks for the info | can anyone confirm that a third-gen ds would bolt up to a t56? thanks guys!
good to know
thanks | now is the difference in diameter (mentioned above) significant in durability?
Gregg, did you have any problems with balance or highspeed/rpm vibration & shaking in the car with the 1LE? Did you use the original u-joints on the alum. ds?
I'm trying to rid my 80mph+ vibration *doh*
thanks | now is the difference in diameter (mentioned above) significant in durability?Gregg, did you have any problems with balance or highspeed/rpm vibration & shaking in the car with the 1LE? Did you use the original u-joints on the alum. ds?
good to know
good to know
I had problems with my original steel ds, I got a lot of vibration with it over 80mph. It was replaced by the dealer for free with an LS1 ds in 98 about a year after I bought it. I used that until about a year ago when I switched to a 1LE ds. Both shafts come new with end caps and u joints installed. I never had any more vibration problems with the LS1 or 1LE.
Gregg, do you still have your LS1 ds? is it for sale?
Does the damper on the front of the LS1 ds make a BIG difference over the 1LE? Looking to nab a low mi. 1LE ds tomorrow.
thanks,
Brian
thanks,
Brian
