How much pinion angle do I need?
Old Oct 16, 2003 | 12:39 PM
aBrotze's Avatar
Like the question says....
How much pinion angle should I have. Right now I have around 3.5 degrees. I have LCAs and a torque arm. See sig for rest of mods.
Old Oct 16, 2003 | 06:13 PM
Janny's Avatar
From what I understand, you need an equal but opposite amount to what exists at the other end of the shaft. IOW, if you have 3 degrees coming off the tranny, you need -3 degrees going into the pinion. One degree off is tolerable, apparently.
Be warned. I am no authority. Others, may have a lot more good info for you.
Old Oct 17, 2003 | 07:36 AM
thermwood1's Avatar
I thought the stock pinion angle was set to 0 degrees, or at least pretty close?
I have heard for drag racing anywhere from -2 to -3 degrees was good for traction. But if you do a lot of driving, having this much pinion angle can wear out u-joints rather quickly.
Bobczar
Oct 23, 2015 11:22 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
Aug 7, 2015 01:26 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
kev93z28
Aug 19, 2002 12:48 AM
