4.10 and a 4l60e
Old Jan 5, 2008 | 04:57 AM
11secgen's Avatar
4.10 and a 4l60e
i didnt do my homework and installed 4.10s on my 4l60e 95 .it seems ok other than shifting into o.d. at 900'-1000'. the 1/8 is mean and the stop light racing is great.anyone else running this setup? p.s. car runs high 12's on a 100 shot with mods listed.
Old Jan 5, 2008 | 06:18 AM
Pyrodawg's Avatar
uhm you should run mid 12s maybe even low 12s-high elevens with a great 60ft on motor.... especially if u have an 847 and ported heads...
something is seriously wrong with ur car if youre running high 12s on a 100 shot
Old Jan 6, 2008 | 08:30 AM
AL SS590 M6's Avatar
Moderator
High 12s on a hundred shot???
What tires and 60'? What's you trap speed?
Old Jan 6, 2008 | 09:48 AM
Greed4Speed's Avatar
My TBSS has 4.10's. They are fun from the line, but suck when you're cruising @ 75 turning 2500 RPM (even with the stock 20" wheels) and getting 16 mpg.
Old Jan 7, 2008 | 09:31 PM
1SlowFormula's Avatar
I am confused as well, for high 12's you shouldn't be carrying enough RPM with 4.10s to shift into 4th with the stock rev limit, if you are running the 847 you should be atleast spinning it to 6000+ depending on supporting mods so that would force a shift at around 112ish MPH and those are low 12's, high 11's kinda MPH. But if this is the case the simple solution for you would be 28" tires, but the numbers are not adding up...
Old Jan 9, 2008 | 07:43 PM
rock1501's Avatar
please tell me that is on a snow tire or something
please post everything on the timeslip so we can figure out what is wrong to give you some help
Old Jan 10, 2008 | 05:31 AM
'94 Bad A Z28's Avatar
You should figure out what is wrong with your car first.... you have way too much done to run high 12's on a 100 shot! My car with a CAI and a 100 shot went 12.1 @ 116.
Old Jan 10, 2008 | 06:37 AM
Wild Willy's Avatar
You re-programmed your computer, right? The tables for shifting are both based on RPM's and MPH- the computer needs accurate MPH to shift correctly-
Even with 4.10's I wouldn't think you would be hitting O.D. until maybe 100 or so- My Caprice/LT1 with 4.10's used to shift into 3rd around 70, =/-, and chirp the tires if I was on it- perfect for merging onto freeways!
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
