Broke Bolt off in Flywheel
Old Dec 10, 2007 | 04:04 PM
B-Rad420's Avatar
Red face Broke Bolt off in Flywheel
I was trying to torque my pressure plate down to 22 ft lbs and I guess my torque wrench was off and I broke a bolt off in the flywheel. What would you guys recomend for removing the bolt? Drill it out? Brad
Old Dec 10, 2007 | 11:40 PM
95LT1conv's Avatar
You can probably just drill a small hole in the center of the bolt and use an easy out.
Old Dec 11, 2007 | 02:00 PM
B-Rad420's Avatar
Hmm I might try that. I found out that Autozone sells flywheels for only 59.95 new so I might just go that route. I would also end up having a new flywheel that will be nice and smooth.
Old Dec 11, 2007 | 04:01 PM
B-Rad420's Avatar
That Autozone one has a $140 core. Do you guys think they just resurface used ones and sell them or they use the cores to make new ones out of? I would like to not have a resurfaced flywheel if possible. Brad
Old Dec 11, 2007 | 04:47 PM
95LT1conv's Avatar
That is what you are going to get for that price.
Old Dec 11, 2007 | 09:00 PM
wrd1972's Avatar
Wow, cant imagine how that bolt would break under that light of torque, I imagine it would easy out just fine as long as it is not bound up or cross threaded.
Old Dec 12, 2007 | 09:52 PM
B-Rad420's Avatar
Yeah I know. I think the torque wrench just stopped working. I felt like I was giving it way over 22ft lbs. Guess i will try a back out bit.
Old Dec 23, 2007 | 11:00 AM
JP95ZM6's Avatar
Is the flywheel off now? If not, once it is there may be a stub you can grab.
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
