Hurst HOTSHIFT ATF safe in T-56?
Old Dec 28, 2007 | 03:40 PM
Mike96z's Avatar
Just wanted to know if anyone has used it before and if anyone knows if its safe? Heard that the fluids we use have to be Silicone based. Not sure if its Synthetic but they do make a synthetic version.
Old Jan 14, 2008 | 11:59 AM
Mike96z's Avatar
anyone?
Old Jan 14, 2008 | 03:02 PM
mbd_73's Avatar
If it says Dextron II or better somewhere it's probably ok.
Old Jan 16, 2008 | 09:09 AM
Mike96z's Avatar
i think it does.
Old Mar 7, 2008 | 04:55 PM
Mike96z's Avatar
I am using Hurst Hot Shift, is this safe to use? I need to know if its silicone based.
Hurst Hot Shift Synthetic Blend Automatic Transmission Fluid AFT Formulated to improve the performance of all automatic transmissions, Hurst Hot Shift synthetic blend transmission fluid provides better oxidation stability, greater film strength, and increased cold flow characteristics. It is formulated for use in late model vehicles and is also ideal for high performance street and race cars, as well as off-road, towing, and recreational activities. * Synthetic Blend * Dexron III/Mercon (very popular) * Hurst part number 1802000
Formulated to improve the performance of all automatic transmissions, Hurst Hot Shift ATF is one of the most advanced custom blended fluids available today. This fluid is so effective in reducing friction that your transmission will actually run cooler!
• Exclusive formula combines friction modifiers, extreme pressure additives and anti-foaming agents to increase clutch plate lock-up, resulting in quicker, firmer and more positive shifts.
• Ideal for use in passenger cars, high performance street and race cars, light trucks, off-road and recreational vehicles.
Hot Shift High Performance ATF meets requirements of DEXRON II, (1-Quart) Part No. 180 1000
NOTE: Maximum benefits and protection are obtained when transmission and converter are fully drained and refilled exclusively with Hot Shift High Performance ATF or Hot Shift Synthetic Blend ATF.
well im guessing since it says its equivalent to DEXRON II.........
IS DEXRON II safe in a T56?
Old Mar 8, 2008 | 08:39 AM
The early T56's (my 94) had a sticker requiring Dexron II; the later ones (I have a spare from a 97) had the sticker requiring Dexron III.
Old Mar 8, 2008 | 01:53 PM
Mike96z's Avatar
but will a 98 T56 take dexron II and be okay?
Old Mar 8, 2008 | 07:00 PM
roguedriver's Avatar
Can't go wrong with GM Synchromesh. Can be had at the GM dealer or online.
Ken R.
Old Mar 11, 2008 | 08:28 AM
Mike96z's Avatar
i already have this in my trans, which is why im asking.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
CARiD
Sep 7, 2015 08:21 AM
