lsd ?
Old Dec 16, 2007 | 02:07 AM
PITCH's Avatar
lsd ?
can anyone help with info on 87 camaro diff question.mine is 87 IROC-Z28 305 tpi 4sp auto 16in wheels, it has drum brake rear end 10 bolt cover plate and a metal tag stating "use only lsd lube". Did this model come with with a lsd as i thought only the disc brake rear ends were lsd's.
pitch.
Old Dec 16, 2007 | 01:44 PM
rskrause's Avatar
Moderator
Does it do a one wheel or a two wheel peal? If you can't spin 'em enough to tell on a dry road, do it in some water.
Rich
Old Dec 16, 2007 | 01:52 PM
matLT1's Avatar
Rich
I would hope he could get them roasting. Back in highschool I drove a rusted out '79 Monte Carlo powered by a monsterous 267ci that put out 115 hp. One day after school, a couple of us decide to have an unofficial burnout contest. I got an excellent one-wheel peel going with that car (on dry pavement), covering the entire back end. So, I think the Camaro can break the tires loose.
Old Dec 16, 2007 | 03:34 PM
The Posi rear was generally available on all the models, either standard, or as an option. Look on your build tag for "G80". The Camaro White Book indicates that 40,823 87 Camaros had a the LSD option.
Old Dec 18, 2007 | 07:33 AM
PITCH's Avatar
Thanks for the reply's, i took your avice Fred and checked the build tag and yes i have a G80.
cheers
PITCH
2000camarostud
V6 Tech
Jan 20, 2004 06:34 PM
ianwells100
Pacific
Oct 20, 2003 10:46 AM
eyeoutthere
Aug 11, 2003 07:19 PM
eyeoutthere
Jul 28, 2003 07:45 AM
94 green drop top
V6 Tech
Feb 9, 2003 06:42 PM
