1st gear on my 93 z28?
Old Jan 6, 2008 | 05:50 PM
GLICKGLOCKMEX's Avatar
ok i have a 93 z28 with the 4l60.as you all know on 93 (and maybe 94) you cant drop your gear shifter down to low gear only 2nd, drive, and overdrive.anyway i heard that there is a clip that you can break or remove to be able to shift into 1st.is this true and if it is where is it and how do i do it?please try to be specific and pics would help too.thanks guys!
Old Jan 6, 2008 | 06:30 PM
even though no one is helping never mind ive found a few threads on this topic
Old Jan 6, 2008 | 06:52 PM
MEAN LT1's Avatar
Gotta love that seach button. Glad you found your answer.
Old Jan 6, 2008 | 09:22 PM
Could be no one was helping because you posted on the wrong forum. This is LT1/LT4 ENGINE Tech
Old Jan 6, 2008 | 09:32 PM
reamo04's Avatar
That is correct, pull up the panel that has park, reverse, etc. Theres a little clip on it.
Old Jan 6, 2008 | 09:37 PM
alley_dog_77's Avatar
93 Z28 has the LT1 in it.
Old Jan 6, 2008 | 09:52 PM
n2ceptor's Avatar
???? My 93Z could always go from 1,2,3,D or D,3,2,1???????? I thought V6s' and some Firebirds were limited??????
Old Jan 6, 2008 | 09:59 PM
reamo04's Avatar
The thing with the shifter select is
If you have 2.73 gears, it goes 2 D OD, etc
If you have 3.23 gears, it goes 1 2 D OD etc
Old Jan 6, 2008 | 11:59 PM
yea i wasnt trying to be an *** about it i just should have searched first thanks anyways guys!!!by the way good info reamo04.
Old Jan 7, 2008 | 02:23 PM
MyShibbyZ28's Avatar
I have P R N D 3 2 1 on my car but I have 2.73 gears
The ONLY for sure way to tell is to open the axle and look at the gears. Second best is to look at RPO codes (GU2 is 2.73).
As for the clip so you can pull it in to first, it's more of a block of plastic. I took a dremel to mine and now I can pull it to first. I won't go in to detail since you said you found an answer.
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
Timberwolf
Jul 20, 2002 08:45 AM
