Broken Trans Mount
Old Dec 19, 2007 | 03:00 PM
NASCR46's Avatar
Broken Trans Mount
What are the symptons of a broken transmission mount on an AT?
Old Dec 19, 2007 | 06:52 PM
showstoppers-96-Z/28's Avatar
Simple, under a "power load" (ex: heavy throttle, power braking) you will feel a "thud" in the center of the car where your shift tunnel/console is located. If it is broken, you WILL know it. If you just have a vibration, that could be due to a number of reasons, unbalanced tires, incorrect tire pressures, drive shaft issues (balance or u-joints), bad alignment, brake rotors warped, and so on. Even if your trans mount was just cracked, that would not cause a vibration unless under full throttle or a heavy power load. Good luck
HarleyZ28
Oct 5, 2015 06:23 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jason Short
Jan 19, 2015 06:34 PM
x7x7
Aug 15, 2002 06:49 PM
