Dot 5 In clutch master and slave?
Old Dec 31, 2007 | 05:49 AM
96supersport's Avatar
i need the higher boiling point, can it be done or stick with dot 4 syn.
Old Dec 31, 2007 | 12:50 PM
Daniel6718's Avatar
i dont think dot5 is compatible...you can only use 3 and 4...go with 4 its more than enough...if you stil hve problems get a serenge and change the fluid in the resavoir ever weekend....that should help
Old Dec 31, 2007 | 01:02 PM
windsma's Avatar
Dot 5 will cause a type of gel to form if u mix it w/ 3 or 4. YOU DONT WANT THAT Fo Sho!
Just use what factory recommends, also 5 may not work with your lines if they are a certin type of rubber.
They make a high performance DOT 4 high temp. check out O'Rileys
Old Dec 31, 2007 | 01:39 PM
OBE1 95Z28's Avatar
Here's a good read, it's based on brake systems: http://www.xs11.com/tips/maintenance/maint1.shtml
Old Jan 7, 2008 | 09:48 PM
ighttt ill just get that dot 4 stuff, since i work at oreillys. =D
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
