Digital Trans PSI gauge found!!!!
I noticed in a search that People can not find gauge's to monitor trans PSI with out putting a line into the cab (which is NHRA no-no)
well Dakota Digital does not list it as working for a trans but i emailed them and they said oil is oil and it will work fine
they have a 0-400 psi sender 2 psi resolution and +/- 8 psi accuracy
Odyssey Series II, Oil Pressure - is the display = $95
SEN-03-5 1/8 / 0 - 400 psi, Universal Pressure Sender $35
$129 plus shipping, (about 10-15 bucks)
i know I'm not very active on here but i though some of you might like to know.
also because of the sender size you may have to get small 1/8 to 1/8 line to move the sender and zip tie/mount it down in the tunnel. not sure as i have to order them and test it out... (hell maybey even a 45* bend will work? )
The only gauges that require a line inside are the mechanical guages. I know autometer makes several tranny temp guages that use a sender and a wire.
99TransAmWS6
Feb 12, 2015 07:23 PM
HuJass
18
Jun 24, 2002 09:19 PM
