Shifter Indicator problem - Stops in the middle of numbers..
Old Jan 27, 2008 | 03:39 AM
camarosource's Avatar
What would cause the Shift Indicator to be off (stopping in the middle of two indicators for example?)
I noticed that (coincidentally after a mechanic touched something under the hood) that the Console shifter seems to have more play that other parts and infact stops in the MIDDLE of some indicators.. Example:
P - LOCKS dead in place.. = Perfect
R - LOCKS dead in place.. = Perfect
N - LOCKS dead in place.. = Perfect
(D) - Stops quite frequently in the middle of "N" and "(D)". Rather than LOCKING in place, I can easily tap the shifter and it will move forward and back between the indicators of "N" and "(D)" enough to be right in the middle of them two.
"D" "2" & "1" all the same way.. Don't stop and STAY in the locked position..
What would cause this?? Loose cable? Badly adjusted Throttle cable?
Old Jan 27, 2008 | 09:41 AM
If it is only the indicator and not the shifter, you probably need to take the indicator apart and clean it. Spilled soft drinks will make it stick.
mattstrike
Mar 11, 2015 07:33 PM
MattFick
Feb 15, 2015 10:16 PM
karpetcm
Feb 9, 2015 09:21 PM
edman
Jan 25, 2015 02:41 PM
tds1213
Nov 27, 2014 12:55 PM
