Guess this noise...
I just purchased a 1996 Trans Am, M6 with 93,xxx miles on it. There is a noise coming from the rear of the car that sounds like something is rubbing. It also tracks along with the RPMs...it doesn't get louder as the RPMs go up, but the noise picks up speed as if the rubbing part is spinning faster. The dealer did tell me there is some fluid seeping from the rear diff but the noise doesn't seem to be coming from the center of the car...more towards the driver side rear.
The driver side rear rim lip also has a spot about 1 inch that is bent in but the tire is seated on the rim and is not leaking air...I'm not sure if the rim itself is bent or if it's just the lip of the rim. The car doesn't shake as I would expect it would if the rim was bent. The car tracks straight so as far as I can tell the alignment is good.
I don't think the car sat for a long time, the guy at the dealership said he got tons of calls on the car...93k miles, M6, t-tops, leather, $4990...no wonder he got a lot of calls.
I don't have a clue what could be causing this...maybe it needs the diff cover removed, new gasket and fluid? Bent axle? Bent rim? Driveshaft?
Any ideas are greatly appreciated!
Thanks!
Thanks!
Brian, great to see you bought another 4th gen. Take it by Seans place this weekend. Heck, he is always the one that diagnosed my car problems.
Post up some pics of the ride. Where did you get it from? I did just see a 4th gen rear with 3 channel abs and 4.10 gear for sale for $250obo. If you need it I can try and find it again.
Later,
Chris
Later,
Chris
Later,
Chris
Later,
Chris
I got the car in Ashland, OH. I found it on autotrader. It's a white '96 TA, M6, leather, t-tops, power everything. The interior is near perfect, the driver side bolster is slightly worn but that's the only thing with the interior. The body is not perfect, there's some spider webbing in the paint on the front and rear bumpers, a little rust in the rear fenderwell, and a couple of other nicks and scratches (but it's 12 years old, what do you expect?).
As soon as I get some pics of the car I'll e-mail them to you. By the way...I filled the tank yesterday and checked the mileage - 24.9 mpg!!! I never got mileage like that in either of the A4s I had before.
Later,
Brian
brothaslide
Jan 9, 2016 12:11 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
