Transmission help plz help fast
Old Jan 17, 2008 | 06:52 PM
Bigrick2324's Avatar
Hey im switching out from my v6 5 speed manual to my 4l60e lt1 tranny cause doing engine swap but as i was taking apart my car i found out that the automatic has some plugs on the side of the shifter will this be a problem when i go to change it out with the 5 speed manual cause i dont thing the 5 speed manual has tho plugs well someone plz right me back and let me know i need help fast
Old Jan 17, 2008 | 06:54 PM
mdacton's Avatar
What plugs are you talking about?
I didn't think the v-6 and v-8 bolt pattern was the same
Old Jan 17, 2008 | 06:57 PM
What do u mean you dont think there the same and see when you take out the shifter of the automatic it has a plug on the right side of it does the manual have the plugs
Old Jan 17, 2008 | 07:06 PM
Green96Z's Avatar
So you're doing an LT1 and 4L60E swap into your V6 T5 right? Just trying to get it straight first. Now what plugs are you talking about? The 4L60E doesn't have a shifter, it has a shift linkage arm on the driver side of it. There are two tranny cooler line connections on the passenger side body, and the tranny wiring harness connector on the passenger side going into the valve body. There is also the dipstick hole on the passenger side, right behind the bellhousing. So what are you talking about? Picture?
Old Jan 17, 2008 | 07:07 PM
mdacton's Avatar
The electric plug? you need the automatic engine harness and PCM to swap to a 4l60E
What v-6 do you have...I know the 3.4L 60* v-6 is not the same bellhousing pattern as a SBC or LT1
Old Jan 17, 2008 | 07:27 PM
hey
im tlking about the electric plug i have the engine harness a pcm harness bud this inside the car where you shift 1 2 d od on the right side of this shifter it had electrical plug plz tell me i dont have to switch out all of that under the hood well some plz help lol
Old Jan 17, 2008 | 07:30 PM
BigBadBlack93Z's Avatar
neutral safety switch?
Old Jan 17, 2008 | 07:35 PM
idk its on the passenger side when you lift up the panel you see the electrical plug in in connected to the whole under dash harness
Old Jan 17, 2008 | 07:36 PM
mdacton's Avatar
sounds like it......just hook it to the clutch pedal switch...search for the swap...plenty of threads with the wiring diagrams
Old Jan 17, 2008 | 07:37 PM
ok so i dont have to switch the whole under dash then right lol
Old Jan 17, 2008 | 07:52 PM
Hey
I cant find anything about the wiring harness in these threads about my car so can someone plz tell me is it my electrical neutral switch or wat
Old Jan 17, 2008 | 07:55 PM
93transam1234's Avatar
I did this swap, and most of the plugs you dont have to worry about.
it called the transmission position switch or CPS switch.
Do a search for m6 to a4 swap and you should get all the info you need.
I am 90% sure you dont need any of them hooked up
Old Jan 17, 2008 | 08:03 PM
Green96Z's Avatar
The 6 wire plug? The wires are for neutral/park switch (no start except in park or neutral), reverse lights (that one you will need) and I forget what the other 2 are for
Old Jan 17, 2008 | 08:29 PM
well can i just hook it up to my clutch switch
Old Jan 17, 2008 | 08:31 PM
mdacton's Avatar
yeah but you need the wiring diagram....same with reverse lights
