Tiny part BIG problem, Where can I get this pin?
Old Jan 14, 2008 | 11:31 PM
gvincent's Avatar
I have a T56 with a T5 metal slave clutch cylinder instead of the plastic one.
It is really a simple problem but I can't seem to find a freaking answer.
I need to buy the simple little pin, roller pin or what ever it is called that is used to pin the GM quick connect hydraulic hose into the slave cylinder which is also a GM quick connect fitting.
I went to the dealer to try and find the simple pin and they laughed at me!!!!
SO WHAT IS IT CALLED?
AND WHERE CAN I GET ONE?
Anybody?
I used a nail which was close, a little loose so it leaks and I cannot get and maintain enough pedal pressure.
Please help!
Thanks,
Greg
Old Jan 15, 2008 | 06:04 PM
Jared 3870's Avatar
Might see if you can't pick one off of a car at a salvage yard, or go grab an entire slave from a salvage yard. Otherwise you will probably have to buy an entire slave from an autoparts store (like 20 bucks) if the dealership doesn't know where to get the pin.
Old Jan 15, 2008 | 06:17 PM
95 Bandit's Avatar
From: What's the difference, I've got nothing for sale
Any jobber will have a selection of roll pins, they're like 20 cents each or something. Grab the nail that's close in size and grab the 2 closest pins.
Old Jan 15, 2008 | 08:25 PM
Bayer-Z28's Avatar
PM T56Joe, or email him.. He's a supporting vendor here and he will know what you need. He may sell you one too.. .
T56 Rebuild FTFW!!! EXCELLENT customer service!!
http://0174de9.netsolstores.com/
Old Jan 16, 2008 | 07:42 PM
gvincent's Avatar
Well so far I have found out it is metric in size and that a 1/8" does not fit, too big.
A new slave is actually $65 that's too much for a pin!
Can't find any junkyards in MA that have manual LT1/T56 kicking around, those trannys go fast as do the hydraulics that go with them.
If I knew of another GM vehicle that uses the same freaking Quick Connectors I would try and find one but right now every junkyard in MA is covered in snow and it is going to be 8 degrees outside this weekend!!!!
I will PM T56Joe.
Thanks,
Greg
Old Jan 16, 2008 | 08:52 PM
my96z's Avatar
Try any hardware store, they usually have tons of roll pins.
Jeff
Old Jan 18, 2008 | 08:20 AM
gvincent's Avatar
I have tried tons of hardware stores and nothing fits, they are Metric pins I believe.
Anyway Joe Huneycutt from
Six Speeds Inc./T56Rebuilds.com
888-937-4411
www.sixspeedsinc.com
was nice to offer to mail me 2 pins, Great guy and very helpful.
If I have any problems with the tranny I will definatly use his shop
Thanks,
Greg
Old Jan 20, 2008 | 02:58 PM
evanbrendel's Avatar
drill out the hole?
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
ced8
Jul 8, 2002 11:03 AM
