Rebuilt 4l60E delayed first shift
Old Jan 28, 2008 | 11:36 AM
BoxcarBilly's Avatar
Trans stays in first gear too long. It shifts at 3500 and then all the next shifts are normal. As I understand the solenoids are both on for first and then 2 is turned off to get second. This is an 02 Avalanche. My rebuilder says it is electrical but I don't know computers only manual valve bodies. It seems that it is a spool sticking or valve body not torqued correctly. Anybody have ideas? Thanks Billy
Old Jan 28, 2008 | 12:45 PM
Performabuilt's Avatar
Supporting Vendor
There are lots of possibilities but I would say the first thing you need to do is have the truck put on a scanner and wacth the gear command, The will tell you wether the issues with the truck or the trans
Old Jan 29, 2008 | 01:34 PM
What type of scanner is required,more than a code reader? Should I go to a transmission shop rather than a local shop? Thanks Billy
Henson071
Dec 30, 2015 09:55 PM
wesley81
Jul 27, 2015 11:31 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
