Whats needed for a 12rib setup?(procharger)
Old May 3, 2003 | 11:53 AM
TravisA's Avatar
What all needs to be changed besides the crank and supercharger pulley? I'm assuming i'll need a new tensioner arm pulley but will i need a new tensioner or just swap out the pulley?
Also i have a 12rib crank pulley from a tpi car can i just use the spacer from my 8rib setup? BTW this is for a p600b model
thanks
Travis
Old May 3, 2003 | 01:39 PM
mongse_1's Avatar
From ATI, you get:
new blower pulley
new tensioner pulley
new crank pulley
keyway for blower pulley
12-rib belt
Also, I've been waiting on mine forever. Hell, I ordered it several months ago.
Old May 3, 2003 | 07:22 PM
Pampered-Z's Avatar
Originally posted by mongse_1
From ATI, you get:
Did you call them? I bought a used system and was missing a few peices. I placed the order on Monday and the parts arrived by the weekend? I was impressed how quickly they sent the stuff out.
Old May 3, 2003 | 07:50 PM
EDS Z28's Avatar
From ATI, you get:
new blower pulley
new crank pulley
12-rib belt
Yep, that sounds about right. You will have to grind the cooling fans a little bit to make it fit. Other than that, it is a piece of cake.
Old May 3, 2003 | 07:52 PM
TravisA's Avatar
Is there somewhere else besides ATI that i can order?
Thanks for the replies
travis
Old May 3, 2003 | 07:57 PM
TravisA's Avatar
Also is the upgrade worth it? Right now with a homemade 4"intake,huge K&N and the 12psi pulleys i'm only seeing around 8 maybe 9 psi.
Has anyone that upgraded from 8rib to 12rib and noticed a pickup in boost?
thanks
Travis
Old May 3, 2003 | 08:04 PM
95 Silver TA's Avatar
Smile
I called Lonnie Pavtis and ordered it from Him. He got them for me in like 3 days and gave me an awesome price too. Mabee you should contact him. Here is his info:
http://www.westol.com/lpavtis/
Hope that helps,
Claude
Old May 3, 2003 | 08:16 PM
mongse_1's Avatar
I bought the pullies through Ramchargers. It took a month to get them originally, only to find they were the wrong ones(maybe for a P1SC or D1. I sent them back several weeks ago and nothing.
I probably should've just called Lonnie and been done with it.
Old May 4, 2003 | 06:13 AM
MEAN LT1's Avatar
thanks
Travis
Need to knwo more about your setup...Are you striked?, ported heads?. My friend had a 12 rib setup running a 12lb pulley and usually saw 12-14lbs on stock heads LT1.
Old May 4, 2003 | 10:34 AM
EDS Z28's Avatar
thanks
Travis
I have used 7, 9, and 12 pound pulleys, with the 12 pound/12 rib putting out the most power by far. It is a big difference from the 8 ribber.
Old May 4, 2003 | 11:20 AM
TravisA's Avatar
My setup is a 355, stock heads and CC 218/230 cam.
Thanks Claude i'll give Lonnie a call and see what he can do.
-Travis
Old May 4, 2003 | 01:05 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
i ordered mine through a local shop(for a friends car) and they were here in about a week. install was straight forward, had to do a little fan trimming.
HectorM52
Jun 23, 2016 08:42 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
