Anyone Successfully Running An STB W/The Aftercooler Setup?
Old May 11, 2003 | 05:44 PM
ZBass28's Avatar
Question Anyone Successfully Running An STB W/The Aftercooler Setup?
Been putting this off long enough and need to get this done. Is there anyone out there that has been able to get their strut tower brace to work fitting over the aftercooler tubing? Any kits out there to raise it up or do-it-yourself ways to accomplish this? Also, will it clear a stock hood?
Lookin for any workable solution
Old May 11, 2003 | 09:08 PM
LWM's Avatar
LWM
I have done it with the Hotchkiss STB, needed to get the mounting brackets modified to raise the STB about 1/2" higher than normal.
It all fits in there, just barely, had to remove the insulation on the underside of the hood.
http://www.members.shaw.ca/mackenzl/...oEnginebay.jpg
Hope this helps
LWM
Old May 12, 2003 | 07:59 AM
ZBass28's Avatar
Great, thanks! I'm running the same STB so it should work out, although it looks awful tight in there where it would need to go. I know my aftercooler tube is already hitting the insulation under the hood.
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Z28STYLE23
Aug 4, 2002 03:30 AM
