Need help w/ Propane injection.
Old Apr 17, 2003 | 03:20 AM
Danny's Avatar
Hey guys,
>How does propane injection go hooked up?
Is it just a like a nitrous kit except for the N2O bottle (propane >bottle) and nitrous silenoid (fuel selenoid)?
>Where does it go injected at?
>Can a kit be made out of a nitrous dry kit?
>How much of a difference would it make on a turboed car running 91 oct.?
The reason I'm asking is because i'm turboing my Z28 LS1 and w/ gas prices being up so high, 100 octane is $5 a gal. Besides i'm going to test this new Twin Turbo kit of mine to the full extent before i recommend it to anyone. That means running it @ (engine safe) high boost levels, making sure everything holds up, taking the turbos to redline and just putting the whole kit through hell. Any questions, comments or opinions will be greatly appreciated.
Thanks guys
Old Apr 17, 2003 | 03:40 PM
TonyJ's Avatar
Check the big Buick/Grand National boards. They have the latest poop. I lost my links, but just google...
Old Apr 17, 2003 | 06:51 PM
got_hp?'s Avatar
as far as i know, the propane is injected via a nozzle setup, into the intake tract, behind the MAF.
dont quote me on that, but im pretty sure thats how it works.
go ask the turbobuick guys to be sure.
the kit is already available with everything you need, so you dont need to "make one" out of a nitrous kit
it is going to make a HUGE difference on a turbo car, especially if all you have is crappy 91 octane. propane is 100+ octane, so it is like driving around with permanent race gas, plus it lowers intake air temperatures by a lot, so the engine is less likely to get detonation.
btw, there are some kits that have "variable" pressure propane kits, that will respond to how much boost you are running.
the guy that sells them is usually on www.3si.org , just search for propane info.
Old Apr 18, 2003 | 12:32 AM
TonyJ's Avatar
While you're at it, research Alcohol/Water injection. Most of the benefits of propane and a little safer...
Old Apr 18, 2003 | 12:48 PM
Danny's Avatar
Propane injection, nitrous injection now water/alcohol. What's next orange juice/milk injection. LOL. Does the water and alcohol go injected the same way as propane and nitrous or is it different? Thanks
Old Apr 18, 2003 | 01:45 PM
ZPaul2Fresh8's Avatar
Why? Are you planning on running a deisel engine
Old Apr 20, 2003 | 10:27 AM
TonyJ's Avatar
Here you go. This should keep you busy for a while. There is a forum for Alky/Water/Propane injection on this board...
http://www.turbobuick.com/messagebd/
LS1M
Advanced Tech
11
Jul 14, 2004 11:15 PM
944v8inDFW
N2O Tech
13
Jul 5, 2004 12:29 PM
11 sec gta
N2O Tech
May 28, 2003 11:59 PM
tireburnin
N2O Tech
11
Feb 24, 2003 01:28 PM
mtxpert
N2O Tech
Feb 15, 2003 06:54 PM
